Topic: Help licenze e 4 decks
Hi, I just bought the license for Virtual 8.2 to use with Hercule DJcontrol AIR, but I did not receive a mail with the number. Also, I would use the skin with 4 decks, is it possible? As? Thank you
Lino
geposted Sat 27 May 17 @ 10:32 am
You won't receive an email with the number - because there is no number.
When you start VDJ 8 it will ask you to log in. This is your registration. When you log in, VDJ will know who you are and apply the correct license.
geposted Sat 27 May 17 @ 12:20 pm
Perfect, all done...
You could tell me if I can use and how to set the Skin 4 deck .... because I tried but I can not use them separately. Thank you
geposted Sat 27 May 17 @ 1:22 pm
