Forum: Old versions
Topic: Tap Buttons Stopped working.with Numark N4
Hey all, hoping someone can help me. I have both VDJ7 and 8 installed, (i installed 8 to see if it would fix the issue), but while using either with my Numark N4 controller, the tap buttons don't work. Any thoughts? I'm on Win 10. Virutal DJ Pro
geposted Sat 03 Jun 17 @ 4:13 pm
if it doesnt work in either VDJ version .. you need to test and see if it is sending midi signals use app in link below .. if not maybe a bad button
http://www.midiox.com/
geposted Sat 03 Jun 17 @ 5:06 pm
Thanks Wickedmix, I'll give that a shot to see if the buttons are sending a signal
geposted Sat 08 Jul 17 @ 1:18 am
