Topic: Load securaty doesn't work
I'm using a pioneer SZ and also a Denon 8000 controller and I've noticed in both of them even with the load security activated in the options you can still load a song into the deck that is playing. Any advice on how to stop a file from loading if the deck is playing a file ??????
geposted Sun 11 Jun 17 @ 9:10 pm
Load security only works if the deck fader is past a certain position.
geposted Sun 11 Jun 17 @ 10:07 pm
So let me get this straight. If the fader volume is down it allows you to load a file. But if the fader volume is up it doesn't. So if that is the case why can't it be the way it was that when the deck is playing it does not let you load a file? I feel that is a more secure way.
geposted Sun 18 Jun 17 @ 2:46 pm
Because if the song is not audible, it doesn't matter if you load a new song over it, and the security dialog is probably just annoying rather than useful.
geposted Sun 18 Jun 17 @ 3:02 pm
You can remap your load button if you like:
play ? nothing : load
geposted Mon 19 Jun 17 @ 7:54 am
