Hey .i just did and update to 3780 and it mess up timecode vinyl the sound is not good no more .the bpm it's jumping a lot and the music sound warped and i have the pitch quality on 2 and i tried it on 0 and 1 and 3 the sound it not good HELP.
geposted Tue 20 Jun 17 @ 3:12 pm
You can try older builds here:
http://www.virtualdj.com/download/build.html
Let us know which build does sound good (if it was indeed the update that caused it)
geposted Tue 20 Jun 17 @ 3:43 pm
Adion;
yes it is definitely the update i went back to Build 3761 and the sound is good.i use serato timecode and VDJ new timecode vinyl
And thank u for responding .
geposted Tue 20 Jun 17 @ 8:28 pm
I even tried to rename the setting.and that did not work.and i tried to rename it too still same thing not good sound.
geposted Wed 21 Jun 17 @ 2:05 pm
Did you try 3771 as well?
geposted Wed 21 Jun 17 @ 2:25 pm
yes that build too not as bad as 3780
geposted Wed 21 Jun 17 @ 2:51 pm
And pitchQuality 1 doesn't help?
geposted Wed 21 Jun 17 @ 3:25 pm
there was always something wrong with pitchQuality 1 i always use pitchquality 2. and now 2 is mess up.
I have a windows 10 64 b
cpu;i7 6700HQ 260GH WITH 324gh turbo boost
A Nvidia Geforce 1060 6gb graphics card
And 24 gb of RAM
And when i use my controller the sound IS Fine .i use VMS5 .its just on Timecode vinyl
geposted Wed 21 Jun 17 @ 8:48 pm
What is your asio driver latency/buffer size?
geposted Thu 22 Jun 17 @ 9:41 am
[quote=Adion]What is your asio driver latency/buffer size?[/quote
I tried it at 512 128 and 64 still the same sound
geposted Fri 23 Jun 17 @ 1:20 am
Is there any fix yet or did the dev team find anything wrong so I could fix it ?
geposted Sun 25 Jun 17 @ 11:59 pm
So far we have not found any difference when testing here.
Is it possible to make a short recording of the problem?
geposted Mon 26 Jun 17 @ 7:15 am
update 3790 timecode sound good again
thank god .
thank god .
geposted Thu 29 Jun 17 @ 3:23 pm
There's nothing in the change log that says anything has been changed....
geposted Thu 29 Jun 17 @ 8:21 pm
sorry i thought it was fix something wrong with the pitchquality 1 2 & 3. its making the tracks sound warped .on my controller they sound fine
geposted Fri 30 Jun 17 @ 4:58 am
I tried to reproduce your issue but wasn't able to.
What devices are you using?
I was using 2x Technics 1210 with VDJ timecode vinyls, going into a NI Audio 4 DJ and to a Numark M4.
geposted Tue 04 Jul 17 @ 8:48 am
I am using AKAI AMX and Epsilon 1300 Turntables .
it has something to do with the pitch quality it use to be good on 2 now with the update its sound bad .2 & 3 sound bad 1 sound good but its jumps sometime and when i press the cue button to cue it up and scratch it like doubles up when i go back and forward .i am using serato timecode but i tried it with vdj timecode and its the same thing
geposted Thu 06 Jul 17 @ 1:18 pm
Anybody using timecode vinyl . The sound is warp and pitchquilty needs collaboration .on 1
I am using a Windows computer
Windows 10
CPU is I7
16GB of ram
Graphics card 960 nivida GeForce
Help please
Windows 10
CPU is I7
16GB of ram
Help please
geposted Wed 12 Jul 17 @ 6:40 pm
I'm using them but on a MacBook but not experienced any troubles like your description.
I use Reloop RP-8000's with Serato or VDJ timecodes and a DJM 850 as my soundcard.
geposted Thu 13 Jul 17 @ 12:32 am
Thanks for responding.yeah on Windows something wrong.i tried it with 2 laptop same thing
And I tried it with Rane Sl3 soundcard and akai amx and American audio vms5 and still the same thing sound warp the dev team needs to adjust pitchquilty 1 2& 3 .I am going to try to record the sound so u guys can here it. On serato it's sound fine but I do not like serato to much I want to stay using virtual DJ 8.2
geposted Thu 13 Jul 17 @ 1:41 am
