Forum: Old versions
Topic: Error is ASIO sound Card. Not enough channels
Windows 10 & the NUMARK option is no longer an option in Sound Setup / SoundCard tab... only gives me ASIO sound card tab which doesn't sync to Numark Mixdeck. Anyone have any advisement? I also downloaded latest Virtual software update 8 but it's still not syncing with Mixdeck.... any help is appreciated tks
geposted Fri 23 Jun 17 @ 1:16 am
Needed to update appropriate drive again... somehow it was deleted or needed to be reinstalled.... worked perfectly - Thanks, all good
geposted Fri 23 Jun 17 @ 7:10 pm
