Topic: Logo on Karaoke
Hi,
Is there a way of removing the VDJ logo from the Karaoke/ Video display?
geposted Fri 23 Jun 17 @ 12:35 pm
VDJ RonPRO InfinityMember since 2010
Have a good look around the VDJ setup options in the video section, all settings. You can also vary its size and position. It may also be possible to specify your own, but I've never tried.
geposted Fri 23 Jun 17 @ 1:27 pm
Yes you can remove the logo, and even add your own. Type logo into the search field in configurations. There is also a Showlogo8 in the plug in section, which will be activated via the video effects tab.
geposted Fri 23 Jun 17 @ 7:39 pm
