Hello! I use a different program for karaoke (heresy, I know!). I run both programs
simultaneously; this has always worked just fine - In the older versions
of VDJ, I would just go into options and click the deactivate video button.
However, that function does not appear to be in Pro 8. Is there a way I can do this?
Thanks for your help!
geposted Fri 14 Jul 17 @ 4:54 pm
Using the default skin, go to the video tab in the centre window. Click the video window to activate and de-activate.
Alternatively you can map a key as video to perform the same function
geposted Fri 14 Jul 17 @ 5:08 pm
Ctrl-V has always opened and closed video output window
geposted Fri 14 Jul 17 @ 11:11 pm
There is also a menu option when you right-click on the Master Video preview to close the Video output but leave the Video Engine running.
geposted Fri 14 Jul 17 @ 11:19 pm
Thank you all for the help!
geposted Wed 19 Jul 17 @ 3:41 pm
