What have you improvised for better viewing as you DJ under the sun as the laptop screen looks like a mirror which makes it difficult to view the rhythm waves? Playlist and controls are in daytime skin and that helps.
geposted Wed 19 Jul 17 @ 1:55 am
Sometimes you just gotta go old school and trust your ears.....
geposted Wed 19 Jul 17 @ 1:56 am
you can improvise a sun shield using a number of materials: cardboard, paper, cloth, bikinis, whatever comes to hand.
but having a cheap portable tent or shade is probably a halfway decent investment.
geposted Wed 19 Jul 17 @ 6:47 am
Have you tried a skin with the daylight option? Makes things really easy to see when sun glare is an issue.
geposted Wed 19 Jul 17 @ 11:53 am
6 dollars from Ikea, https://www.google.com/amp/s/www.pinterest.com/amp/pin/341077371756222470/
Or you could spray paint a small cardboard box and do it yourself....
geposted Wed 19 Jul 17 @ 2:04 pm
the SOUND INSURGENT wrote :
spray paint a small cardboard box ...
Sounds music to my ears. thx all
geposted Wed 19 Jul 17 @ 4:02 pm
And just to clarify the paint is just to dress the box up it's really not needed but you don't want to be known as a DJ who uses cardboard , lol!
geposted Wed 19 Jul 17 @ 4:12 pm
@the SOUND INSURGENT that's a good one. lol
geposted Wed 19 Jul 17 @ 8:37 pm
Look here.
geposted Fri 21 Jul 17 @ 8:08 am
