Topic: BPM is automatically synced when loaded?
Hello VDJ community,
I just updated VDJ to the latest version and now I have a problem:
When I load a track into a deck it has the original BPM. But when I start this track while another track is running on another deck it automatically syncs the BPM. How can I change this setting?
Thank you
geposted Thu 20 Jul 17 @ 8:56 am
locodogPRO InfinityModeratorMember since 2013
Sounds like smartPlay, check the dot (aka snap button) under the pitch slider.
geposted Thu 20 Jul 17 @ 9:16 am
Yessss, thank you!
One more question: Smart loop is just correcting the length of a loop, right?
geposted Thu 20 Jul 17 @ 9:24 am
Smart loop, yes.
Quantize loop also corrects position to place it perfectly on the CBG (in case you need that option as well)
geposted Thu 20 Jul 17 @ 12:10 pm
Since the update it doesn't save the smart settings. Every setting that can be applied to various decks won't be saved in connection with my controller. :/
geposted Sun 13 Aug 17 @ 9:54 am
