Hi all! I'm experimenting with a third hidden deck to accept a mic (or AUX in) but I am struggling with some parts of the code...
I need the output to be independent of the crossfader...at the moment deck 3 is 'assigned' to the left side of crossfader, not very useful :-/
Any ideas?
Any ideas?
geposted Tue 08 Aug 17 @ 1:33 pm
crossfader_disable command assigned to that deck perhaps?
geposted Tue 08 Aug 17 @ 1:46 pm
Doesn't work..
I have realised i can do it by switching to the default skin and unchecking crossfader assignment for deck 3 in (four deck mode)....now just to find that code!!
geposted Tue 08 Aug 17 @ 2:12 pm
something like action="deck 3 leftcross off & deck 3 rightcross off maybe?
So long as I disable deck 3 in default first, then switch back! hahaha!
geposted Tue 08 Aug 17 @ 2:23 pm
Check the default 4 deck skin, that has XF side allocation, left, right, a click on an already chosen side makes that deck a sub master (not on the XF or maybe it puts that deck on both left & right of the XF,! Who's to know)
Not sure on what script it calls (use script learn) but I think if you append the script with
0 (zero)
Or
off
It will do what you want.
*edit*
Perform the action in your skins oninit.
0 (zero)
Or
off
*edit*
geposted Tue 08 Aug 17 @ 3:58 pm
Thanks Locodog; makes sense now, especially the oninit bit!
I think I've been chewing too much aluminium foil haha!
geposted Tue 08 Aug 17 @ 8:28 pm
