I have gone through my collection of music in the browser and colour coded them as seems logical to me. I have left some white. some are yellow, some green and finally purple for the current best floor fillers.
What I would like to be able to do is type in the search bar to call up all yellow or purple. For example, into the last hour of a gig and just want the most relevant top floor fillers coloured purple. Bare in mind there is also a lot to do, lights (all manual here, DMX is to robotic)....you know how it is. I just want to short circuit some of the time searching takes.
So....is it possible?
geposted Fri 18 Aug 17 @ 9:37 pm
No, you can only search within the "Search" fields. Click on the Search Options radio button next to the Search to see which ones are available.
A workaround is to create Filter Folders based on color (e.g. color=red as filter), select the Filter Folder with the needed color and then search within that Folder.
Or even better, create a Filter Folder as .. group by color and you will automatically get nested folders per color
geposted Sat 19 Aug 17 @ 12:00 am
You can also enable a column in the browser showing colour and then sort on colour. You will then get all the same colours grouped in the browser display. ;-)
geposted Sat 19 Aug 17 @ 9:36 am
Great suggestions, they work brilliantly for me! Many thanks to you both. It never ceases to amaze me the things VDj can do.....Brilliant!
geposted Sat 19 Aug 17 @ 10:38 am
Hmmmm.....Ok.....So i created a filter folder and all was well. but after I closed VDj and reopened it, the folder is no longer there. Do I have to create it every time I open VDj? I cannot see any way to save it,
geposted Sat 19 Aug 17 @ 9:32 pm
If you re-create and re-open VDJ, its still not there ? If not, there may be a saving issue related to write permissions at some path/folder/drive. Check the "filters" folder as well.
geposted Sun 20 Aug 17 @ 1:04 am
Well spotted, it was the write permissions to the Filters folder in VDj. Many thanks for the direction.
geposted Sun 20 Aug 17 @ 10:14 am
So, I have had success in making my coloured lists, all working fine. But now I have a problem, some tracks have the red X against them, I understand why they have, but what I want is to get rid of them. I have tried to delete but that has failed. Help would be appreciated.
Ahh!...Sorry, figured it out...... Doh!
geposted Mon 21 Aug 17 @ 7:15 pm
