Forum: Old versions
Topic: Strange Behaviour
Hi all,
I'm quite technically minded - I've built my laptop to a very high spec - so it shouldn't be part of the issue.
- Intel Core i7-2760QM
- 16GB DDR3 RAM
- 128GB Crucial M550 SSD
- Windows 10
I use Virtual DJ 7
I use a Yamaha DSP-A592 Amplifier
2 Tannoy Mercury M3 Floorstanders
2 Pioneer S-Z72 Speakers
I've got the Numark Mixtrack Pro.
Sometimes, half hour into a set, the second deck doesn't let me load any tracks to it. No matter what I try.
This can be really annoying in live streams and house parties as it makes me look like a prat.
Why is this?
Also, my laptop sometimes completely turns off.
Doesn't overheat at all, checked temperatures with HWMon and I have the bottom plastic cover off when I DJ as well as a cooling pad with 6 fans on.
Only ever does it when doing a set in Virtual DJ.
It's a high spec machine, it shouldn't be doing this.
Yes, it's a legit copy of VDJ7.
Help please!!!!
geposted Mon 04 Sep 17 @ 4:49 pm
bad idea to be running a laptop with the bottom cover off ... all kinds of bad things can happen
you are using build 7.4.7? if not get it from your account page / licensees
about loading tracks ....
have your tried to drag and drop a track on the deck or just the load button on the controller?
could be that the load button is going bad if that is what doesn't work only.
geposted Mon 04 Sep 17 @ 6:18 pm
