I'm using VDJ8 with today's update 9/12/17 and a Numark Mixtrack 3
I'm trying to map jogSensitivityScratch found in the options menu to a knob . Is it possible?
If there is a way would it also work for rampStartTime, rampStopTime, rampScratchTime also?
I can't seem to find a definition that corresponds to these settings. Have tryed entering as it's written in options. However to no known effect.
Any help would be appreciated. Best wishes.
geposted Thu 14 Sep 17 @ 5:45 am
Try:
setting 'jogSensitivityScratch'
In my test (on the custom knob) it then adjusts the value between 0 and 1
If you need to go above 1 (I don't know this setting so well, so I'm not sure if it's relevant), you need to add some kind of multiply to it.
That's also doable in a script using param_multiply and/or & param_add
Same thing is possible:
setting 'rampStartTime'
setting 'rampStopTime'
setting 'rampScratchTime'
If you need it to switch between specific values - like 8 different ones one a pad page - you can also set them directly, like
setting 'rampStartTime' 0
setting 'rampStartTime' 0.5
setting 'rampStartTime' 1
setting rampStartTime 2
... and so on
geposted Thu 14 Sep 17 @ 2:23 pm
Will give it a try after work. Thank you
geposted Thu 14 Sep 17 @ 4:08 pm
