Topic: Max value for scratch quality?
Does anyone know the highest value you can enter to have it output the highest quality scratch? The description says the higher the number the better and that default is set to 8. Can't seem to find what's considered best or highest value allowed.
geposted Thu 14 Sep 17 @ 5:49 am
Around 14 is probably the highest you need for best quality.
After that cpu usage just increases for only very little gain in quality
geposted Thu 14 Sep 17 @ 6:07 am
Thank you will give it a go. I have another post up in regards to mapping jogSensitivityScratch to a knob. You wouldn't possibly know anything in regards to that would you? Thank you again
geposted Thu 14 Sep 17 @ 1:28 pm
