Topic: POI a disaster/inconsistent VDJ 8.2 b3903
I can't get this brilliant feature to work. So far it has been extremely inconsistent and sometimes doesn't work at all. When I try to set a beat anchor to signify a tempo change it just won't stick. Also when I choose Beat Anchor from the menu more than half the time the BPM text input bar won't open so I can't even set the beat. Also for some reason Virtual DJ is preloading all of my tracks with the full range of POI points even though I don't want them preset ahead of time. It's a real mess, a cluster bomb and a hassle just to do a simple task like set a Tempo change marker or cue point. I really love this feature but the POI is so buggy I can't get anything done.
geposted Wed 20 Sep 17 @ 7:24 am
Is it a b3903 issue?
Because I've used the POI a few times (and made YT videos about it), and I haven't run into any bugs...
geposted Wed 20 Sep 17 @ 8:25 am
I think it might be a Beta issue. I managed to disable the multiple preloaded cue points by unchecking the "show all" box in the POI and hopefully that will solve my issue with the faulty Beat Anchor mapping as well.
geposted Sat 23 Sep 17 @ 5:59 am
