So I have set up cues in a way that the first beat of every drop has a Hot_Cue.
The thing I wanna do is when I'm playing music and reach the first drop I want to jump the second drop without losing sync and staying on beat.
So let's say the first drop is on beat 80 and second drop is at 120, when I reach beat 80 I want to press a button that jumps the the cue at 120 and continue from there.
The problem is I press it at say 80.6 and it sounds off beat.
I want to customize a button on the keyboard in a way that it calculates the difference between 120 and 80 (40 beats) and use goto +40.
The problem is every song has a different delta so is there a way to calculate the differences in beats between to cues and add it to goto ?
geposted Wed 20 Sep 17 @ 12:45 pm
Can't you improve this by simply enabling "Smart Cue"?
geposted Wed 20 Sep 17 @ 3:10 pm
If you want to do this auto every time make first cue a action cue.
Set action to goto_cue x where x is cue number
geposted Wed 20 Sep 17 @ 4:56 pm
Still for jumping between hotcues without losing sync the correct way is to enable smart_cue for that deck.
geposted Wed 20 Sep 17 @ 8:05 pm
Set up an action POI and you don't even have to press the button anymore.
geposted Thu 21 Sep 17 @ 7:44 am
Ah okay ! Thank you very much I didn't know about these features
geposted Thu 21 Sep 17 @ 9:52 am
