Please excuse my ignorant question. I tried to find an answer in the comments but ended up confusing myself. I remap buttons all the time but this is a little tricky.
What I need to do is remap my controller's dedicated filter knobs on my Denon MC4000 from the default VDJ filter to the lovely SBDJ filter. I don't just want to have the filter knob control slider 1 in general but specifically slider 1 for the SBDJ filter. Also, ideally I would like to have the SBDJ effect turn on as I turn the knob either way (left or right) of 12 o'clock, or turn on automatically when I open VDJ so it's ready to use.
Thanks in advance for any help.
geposted Thu 28 Sep 17 @ 11:51 pm
I made a video a while back that may help you:
If you change the script from the video (and video description) to instead use the SBDJ Filter effect you end up with something like this:
param_greater 52% ? effect_slider 'Filter SBDJ' 1 & effect_active 'Filter SBDJ' on : param_smaller 48% ? effect_slider 'Filter SBDJ' 1 & effect_active 'Filter SBDJ' on : effect_slider 'Filter SBDJ' 1 & effect_active 'Filter SBDJ' off
geposted Fri 29 Sep 17 @ 5:47 am
