Here is my color definition for one of the controler's pads:
<color deck="1" values="table" note="36" name="Pad 01 LED" table="0=black,1=darkgray,2=gray,3=white,6=red,7=darkred,9=orange,10=darkorange,13=yellow,14=darkyellow,24=green,22=darkgreen,33=cyan,35=darkcyan,45=blue,47=darkblue,49=magenta,51=darkmagenta,57=pink,59=darkpink"/>
In VDJ all colors show up correctly except for red and green. I type in "Color red" and the pad lights up white.
1. This happens to all pads
2. It does not matter what value I give "Red" or "Green" in the definition
3. The pads work correctly in other programs
geposted Sat 07 Oct 17 @ 9:56 pm
After removing Red and Green from the color table completely, the pads still turn white when sent the colors in VDJ.
geposted Sat 07 Oct 17 @ 9:57 pm
I have discovered this is a bug. I am Running VDJ 8.2 b3870
Having a second controller using with color values defined in a table causes errors in the MIDI sent to the controllers.
New Thread here: http://virtualdj.com/forums/220173/VirtualDJ_8_2_Technical_Support/Colors_messed_up_when_second_controler_connected.html
geposted Sat 07 Oct 17 @ 11:49 pm
what controller ?
geposted Sun 08 Oct 17 @ 1:09 am
