Forum: Old versions
Topic: VDJ 7.4.7 and VMS4 problem after Windows Update
Hi,
I updated windows 10 to the latest build. Now the Mixer do not act like before. I had Chan1&2 : Samples/preview / Chan 3&4 : Deck1 / Chan 5&6 : Deck 2. Earlier when i pushed CUE button on CH1 I could pre listen at headphone. Ch2 and Ch3 I mixed my Desks.
Now it woks only a bit while using a different configuration at Soundsetup, for e.g. I choose Can 1&2 : Deck 1 / Chan 3&4 Deck 2 it works with Ch2 and Ch3 on my VMS4.
I hope I explained it somhow you can understand.
Thanks Michael
geposted Tue 17 Oct 17 @ 12:24 pm
geposted Tue 17 Oct 17 @ 1:14 pm
Hi djdad,
thanks, that works now. Have now only one issue. When I push Cue at Ch2 or Ch3 (mix Channels) I hear only the deck at Headphone from the side the fader is set. Bevore I heard always the Sound from the Deck, doesnt matter what fader position was.
Any help on that, also?
Thx Michael
geposted Tue 17 Oct 17 @ 2:06 pm
First i would try to re-install the ASIO drivers. It could sort it out.
If what you get on your Headphones is affected by the crossfader or Volume faders positions, then probably your audio Setup is not correct or something is messed up in the Midilogs Routing.
Also make sure the Headphones CUE/MIX knob is at the CUE position.
geposted Tue 17 Oct 17 @ 2:32 pm
After uninstall Asio an VDJ, delete all Database etc. and install VDJ and than Asio, everything works like it shoud.
Thanks a lot.
regards Michael
geposted Thu 19 Oct 17 @ 10:05 am
