Forum: VirtualDJ Plugins
Use this forum if you have questions about plugins development, or if you want to talk with other developers.
Topic: List Of Mac Compatible VDJ8 Audio Effect Plugins
Hi
I've had a really frustrating time trying to find mac compatible audio effect plugins for VDJ8.
Can anyone point me to a list of plugins that are tried and true, and work on mac OS?
Or, just post your favourites here...
Thanks!
V
#mac #effects #plugins #maceffects #vst #vsteffects #vstplugin
geposted Tue 24 Oct 17 @ 12:08 pm
Anyone?
geposted Thu 26 Oct 17 @ 10:22 am
geposted Thu 26 Oct 17 @ 10:56 am
Think he's looking for VSTs
geposted Thu 26 Oct 17 @ 4:50 pm
Yeah, VSTs or any other compatible effects that are compatible with VDJ8. There are loads out there that appear to be mac compatible, but I can't get them working in VDJ8... Surely someone knows what's good in this department?
geposted Fri 27 Oct 17 @ 12:53 am
djcelPRO InfinityModeratorMember since 2004
Which build of VirtualDJ are you using? Test again with build higher than 3928 please.
geposted Sat 28 Oct 17 @ 10:26 am
I was running an older version, but just updated and seem to have the same results.
Any chance that some other skin, padbank etc... add-on might be getting in the way?
geposted Sun 29 Oct 17 @ 1:23 am
Without knowing which plugin you tried it's difficult to say why it doesn't work.
geposted Sun 29 Oct 17 @ 6:09 am
Ah... I've worked out what I was doing wrong.
Still, is there no list or repo of VDJ friendly effects out there?
K
geposted Fri 03 Nov 17 @ 11:44 pm
pretty much all of them should work
I would check out turnado kinda a Swiss knife many FX in one.
https://sugar-bytes.de/en/turnado
its really the only FX type vst I use.
geposted Sat 04 Nov 17 @ 1:31 am
Thanks for the tip... Turnado looks pretty great.
Just trying to wrap my head around mapping it in VDJ... Can you point me to, or give me a quick how-to?
Cheers!
geposted Sun 17 Dec 17 @ 11:57 am
geposted Fri 22 Dec 17 @ 5:48 pm
I've ended up buying Turnado... Any chance you'd share how you use it, in terms of mappings and calling specific presets?
Thanks,
k
geposted Thu 18 Jan 18 @ 5:25 am
i am using one of these to control turnado
i have mapped the knobs to
deck 1 effect_slider 1
all the way to
deck 1 effect_slider 8
then
deck 2 effect_slider 1
all the way to
deck 2 effect_slider 8
then i mapped two of the buttons to activate on each deck
deck 1 effect_select 1 "turnado" & effect_active
deck 2 effect_select 1 "turnado" & effect_active
as for the presets i just use the plugin interface to select the one i want to use
the knobs really do all the work with this plugin anyways that is the way i use it.
geposted Thu 18 Jan 18 @ 10:18 am
Yep, that's essentially what I have going on... just hoping to work out how to call different presets from the controller, to avoid fiddling around with the mouse.
I've also had VDJ8 crash if there are different presets called on the left and right decks. You experienced that?
geposted Fri 19 Jan 18 @ 3:29 am
no crashes here but generally only using it on 1 deck at a time with the same preset on both
been using it more then a year so i am sure it would have crashed by now right?
geposted Fri 19 Jan 18 @ 11:12 am
