Topic: ION DJ2GO
Hey All,
I'm looking at buying the ION DJ2GO. It looks exactly like the numark one but a bit cheaper.
Will this work just the same with VDJ?
I want to use the VDJ install i already have (default, 4 deck) because as I understand the VDJ that comes with it has a custom skin which i dont want to use
so yeah top question is the main one :)
Thanks
Joel
geposted Thu 16 Nov 17 @ 10:05 pm
I have one and it is the same as the Numark one. It works just fine, I use it as a back up device and have no issues with it.
One thing that you will need is a USB soundcard to plug into the pc so you can use headphones. The one I have I got from ebay for a fiver and it all works great.
There is a Mk2 version out now that looks even better, but if budget is tight, this will do you well.
geposted Thu 16 Nov 17 @ 10:12 pm
