I was using VDJ on battery when the laptop suddenly shut off at only 50% battery, upon re start and loading up VDJ it had reset every tweak I'd ever done. My question is - does VDJ have a restore custom settings mode somewhere?
geposted Tue 21 Nov 17 @ 7:11 pm
hmmm, after re starting vdj 5 times it has brought back all my tweaks and settings.....consider this solved
geposted Tue 21 Nov 17 @ 7:53 pm
No, but you should back up the Documents>VirtualDJ folder regularly just in case something like this does happen.
geposted Tue 21 Nov 17 @ 8:22 pm
I do just that every week regardless, just a bit of a shock to see it suddenly go native on me
geposted Tue 21 Nov 17 @ 10:42 pm
This is quite disturbing.
Closed VDJ a few days ago, all good, previously having used the software for well over a year without any problems.
Just now I launch VDJ and immediately a Window pops up
virtusldj8.exe - No Disk
There is no disk in the drive. Please insert a disk into drive F:. ( I include the colon and full stop as that appears in the message)
Buttons 'Cancel' 'Try Again' 'Continue' (None of these work they just make the message remain and warn me again)
At the same time the program UI is visible behind the message and then Auto Updates.
then I see all my playlists, my Main hard drive with my music files (within the laptop not external) everything has gone and VDJ has defaulted to look like a fresh install version.
I check Settings
It is still registered to me, my Denon MC6000 Mk2 is still listed (although not connected when this happened)
What the hell is going on??
If this was just before a gig I would be royally screwed.
Yes I have playlists backed up but if the HDD preference has been removed during this update I am going to have to relocate every file in my playlists. I check the HDD and thast is totally fine and has not been moved to a new location etc.
Tech details are
Lenovo Core i7 2 GHz with 8 GB Ram - 64-bit
Windows 10 Home (fully updated)
Installed VDJ version v8.2 b3967
Having gone from PCDJ (all versions for over ten years / via Serato to then, out of frustration with Serato, finding what I thought was a solid reliable playout software in VDJ this has truly wobbled my confidence BIG TIME for future pro gigs.
Any suggestions or help most welcome, thanks, Rob
I check Settings
Tech details are
geposted Wed 22 Nov 17 @ 8:20 pm
first suggestion stop posting this everywhere!
second make sure all external drives are connected and working reboot pc and try again after fully booted
geposted Wed 22 Nov 17 @ 8:37 pm
Nice welcome to the forum.
This duplicate posting was a mistake, it's not everywhere, just on it's own as a stand alone post because the symptom I am still suffering is different to this post thread. I tried to delete the one duplicate unsuccessfully.
As explained in my post I do not have external drives, my music files are on the internal drive which is working, active and not corrupt in any way. VDJ has simply 'lost' all settings, playlists and the ability to connect to my one internal HDD.
It appears I am on my own here and will likely need to re-install VDJ and sort my entire library again from scratch.
Thanks for the advice and the ticking off.
geposted Fri 24 Nov 17 @ 7:34 pm
