Topic: TouchDAW Midi device recognized and active but no effect on software
Hi,
I'm testing controller options to decide if I want to buy a full license.
I've installed TouchDAW on my android tablet, and connected it to my windows 10 computer through rtpMIDI successfully.
In VDJ 8 settings > controller, I'm able to see the MIDI input of TouchDaw, say 0-BUTTON42, and map it to an action for testing purpose, say "deck 1 play_pause".
I know this action works as I tested it as a custom button, but when assigned to my TouchDaw button, it doesn't trigger in the software.
Any help would be appreciated.
geposted Tue 05 Dec 17 @ 4:59 am
what if you map it as .. loop 1 ? Does it work ?
Are the buttons work as momentary (x7F while button is down and x00 when released) or toggle (first press sends x7F, second press sends x00 and so on) ?
You could use MIDIOX (Google it) to see what kind of MIDI notes you get)
Also keep in mind that you will need a license to use any custom device or Hardware. But you should be able to test for 10 mins on each restart.
geposted Tue 05 Dec 17 @ 8:07 am
Thank you for your message.
I also tried "loop 1" and "loop". These commands both work as custom buttons, but give no result through the tablet & TouchDAW.
It looks like these are normal button that deactivate on release.
Yes, the two virtual buttons I've been trying to map come out as F# and G. They both send an "off" message on release.
geposted Wed 06 Dec 17 @ 12:02 am
