Hi all,
Wonder if anyone can answer this one for me (might be stupidly simple.) I've got a Rode Procaster, XLR, plugged into a Behringer Q802 USB Mixer. The mic works fine, but nobody can hear me speak.
Tried all the settings, nothing works. Am I missing something (like a line in cable to the computer, 3.5mm to 1.5) from the external mixer? Or is the mic not compatible with VDJ at all? Trying to find a workaround if possible. Any advice?
Thanks
Thanks
geposted Wed 03 Jan 18 @ 10:25 pm
if you are broadcasting then you need to set a mic in for it in VDJ
geposted Wed 03 Jan 18 @ 10:28 pm
In the settings? I've tried everything there, and nothing wants to know.
geposted Wed 03 Jan 18 @ 10:31 pm
So the mic plugs into the Behringer - but then what? How are you using the Behringer with VDJ? How is it connected?
What's your VDJ audio config? How are you cueing?
geposted Wed 03 Jan 18 @ 10:40 pm
This is why I think I need an extra cable - it's plugged into the mixer, but nothing else.
If I just need a cable, then it's an easy fix.
I changed from the Rode Podcaster, the USB version. So I haven't changed the settings much. Mic i've only fiddled around with.
geposted Wed 03 Jan 18 @ 10:44 pm
Can't see it ..............
do just the audio config window so we can read it
geposted Wed 03 Jan 18 @ 11:47 pm
Sorry, here's a better view.
geposted Thu 04 Jan 18 @ 12:02 am
no its not better but nice try
geposted Thu 04 Jan 18 @ 12:05 am
Can you perhaps download Gyazo and take a screen grab closer in? And then put the link here? Without being able to see the screen grabs on here, it is hard to help. :)
geposted Fri 12 Jan 18 @ 3:41 pm
