For reporting any bug, questions or comment related to the latest version of VirtualDJ
(NOTE: VirtualDJ continuously updated, so many older topic on this forum are most probably already fixed in the current build)
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
Topic: Virtual DJ dont work!!!!
I just got a new computer. my old one is done.......so i downloaded VDJ 8 from my account in witch i had VDJ 8 pro infinity.........i click on the window key from my license......VDJ was uploaded but i can not do anything.....i cant get my music to play or anythijg else!!!!!! im a missing Something......thanks
geposted Thu 04 Jan 18 @ 11:34 pm
Is there an error message, does nothing happen or what?
geposted Fri 05 Jan 18 @ 4:32 am
Super dan...I'm in calgary ...the issue lies in your setting jn your sound set up.. you need to go to configure and set up your settings.. I will check back. I can make a youtube video if needed..
geposted Tue 09 Jan 18 @ 4:56 pm
Did you transfer your music and database to the new computer? Does VDJ see this music?
geposted Tue 09 Jan 18 @ 10:24 pm
pls I need a help<> my virtual DJ is not working. I downloaded and install it. I can play music. bet is not working with my mispult DJ console. I have Hercules mk4. plz what will I do
geposted Tue 06 Feb 18 @ 6:30 pm
You need at least a controller licence for your controller to use VDJ with it.
geposted Fri 09 Feb 18 @ 1:58 pm
