Topic: Virtual dj on linux
NiquidHome userMember since 2017
Hello so i have managed to get virtual dj working on linux. Using WINE It woks perfectly fine and detects my party mix. Yet it shows my party mix as an "Analog Mixer". It says i need a licence for it. In Mixxx it works fine. What do i need to do to have it detect my party mix as a party mix and not a "Analog mixer".
Note:My other controllers work fine.
geposted Fri 19 Jan 18 @ 2:30 pm
Can you post a screenshot showing PartyMix detected as "analog mixer" ?
If by this you mean the warning message you see at the bottom of the Audio tab in VDJ Settings, then probably you are trying to use an Ext Mixer Audio setup (deck 1, deck 2 ..etc) instead of Master & Headphones.
The Ext Mixer Audio setup indeed requires either a "analog mixer" Plus license or a Pro license, but whatsoever the PartyMix doesnt operate properly with such a audio setup.
geposted Fri 19 Jan 18 @ 6:44 pm
