Topic: HDMI Splitter
So what’s everyone using when it comes to splitters??
Looking for a cheap but reliable splitter. I need one that takes a single HDMI input and turns it into 2.
Thanks for the time and info.
geposted Mon 05 Feb 18 @ 1:40 pm
djdonnPRO InfinityMember since 2006
geposted Mon 05 Feb 18 @ 2:37 pm
For future compatibility i would ensure it supports hdcp for protected content , they don't cost much more and you will not be caught out
geposted Mon 05 Feb 18 @ 9:21 pm
I use the same one, but make sure that you test it as soon as you get it. Like most things that are made in China (everything), there could be a defect, and you want to find out right away, so you can exchange it. I tend to buy stuff that I might need, and forget about it until I need it. Now it's defective, but I'm past the return date. I also buy two of everything, because stuff just does not last. It does work like a charm. They make a 1 in 2 out, but I think you should go for the 4 out, because you may want to expand.
geposted Mon 05 Feb 18 @ 9:51 pm
Hi. I use the same. Never have a problem. 2 years of use
1x 4. Outputs. Check the conpatibility of cables and device.
GK
geposted Tue 06 Feb 18 @ 5:12 am
