Topic: Urgent Need help!
I'm connecting djm900nxs2 and two cdj2000 nxs2 players. I can't get the players to work!! Need to play in about an half hour
geposted Fri 09 Feb 18 @ 5:41 pm
Using silversleek3
geposted Fri 09 Feb 18 @ 5:43 pm
Screen doesn't give me info, stay blank. Vdj click with mouse in the play in vdj and song only stutters
geposted Fri 09 Feb 18 @ 5:48 pm
Have you put them in HID mode? I'm sure I read that here somewhere.
I'm surprised there's no setup guide for these in the manuals area...
geposted Fri 09 Feb 18 @ 5:51 pm
I think not... How?
geposted Fri 09 Feb 18 @ 5:52 pm
Do they show up in the controllers tab?
Should just be Link->USB->Ok same as other cdj's I think.
geposted Fri 09 Feb 18 @ 5:55 pm
Y they are recognized in vdj and the controllers show 1 and 2
geposted Fri 09 Feb 18 @ 5:56 pm
Mappings selected as factory default?
geposted Fri 09 Feb 18 @ 5:59 pm
Yes not changed. Standard skin same problem
geposted Fri 09 Feb 18 @ 6:02 pm
Does this help?
PhantomDeejay wrote :
You need to run the latest firmware on your CDJ's to activate Advanced HID. In order to activate Advanced HID, go to the UTILITY settings on your CDJ by pressing and holding the MENU button (located at the upper edge of the device). Set the HID SETTING to ADVANCED as shown in the image below:
[IMAGE1]
Finally exit the UTILITY settings by pressing MENU again
geposted Fri 09 Feb 18 @ 6:05 pm
Keys don't show up in the controller tab when pressed and the controller is selected?
geposted Fri 09 Feb 18 @ 6:07 pm
Just did firmware update browser works but song stutters by pressing play
geposted Fri 09 Feb 18 @ 6:24 pm
It works now. Only connected 2000 on USB one, second 2000 on USB 2. Without djm connected
geposted Fri 09 Feb 18 @ 6:42 pm
