Topic: Broken SPIRAL FX
SPIRAL FX doesn't seem to work properly in my VDJ 8 at all. I've noticed it for a while but only just asking now. Any pointers to why? Turning it on and the music goes silent. Thanks in advance.
geposted Fri 16 Feb 18 @ 12:43 pm
As I posted on FB, it works ok for (if I understand you correctly):
geposted Fri 16 Feb 18 @ 1:10 pm
Not what my spiral does. Ohh dear. Just did a full reinstall, same issue. Not working as intended at all.
geposted Fri 16 Feb 18 @ 1:39 pm
VDJ8.2 b3994 is that the same build as yours?
geposted Fri 16 Feb 18 @ 3:36 pm
Fixed in early access.
geposted Fri 16 Feb 18 @ 4:03 pm
