With a Pioneer DDJ-RR Controller, sometimes when access a usb disk on my laptop or disconnect a pendrive o reconnect it, some silence and reset pitch occur. Only little audio cut and return audio again (not stop, not lost midi connection, only audio and reset pitch).
When use cdj-2000 this not occur.
All usb state are set on device manager on windows 10 for not disconnect for save energy.
Any suggestions?
Any suggestions?
geposted Sat 17 Feb 18 @ 7:41 am
Update problem:
This issue is only when plug a pendrive or external disk. Not when unplug.
With Rekordobx not occur.
The time of the silence is relative to the type of usb disk are pluged in. If is a pendrive, silence is tiny, but some hardisk make longer silence.
geposted Wed 21 Feb 18 @ 2:01 am
