Topic: Latency Question on skipping music
skell11PRO InfinityMember since 2006
Team,
I have an older PC running Windows 7, I upgraded to VDJ 8 and I am having some skipping problems when I type to search songs the program starts to skip the song playing. Latency is on Automatic and I may want to try a higher latency number. What is an example of this? Or if you pro's have any suggestions on this would be helpful.
thanks ...
geposted Mon 19 Feb 18 @ 8:51 pm
You need to tell us which sound interface you are using and whether it's WASAPI or ASIO drivers. Thanks.
geposted Mon 19 Feb 18 @ 9:01 pm
Sorry, I am not sure on that one. How do I find out which one I am using. The soundcard in the machine is a sigma tel audio.
geposted Mon 19 Feb 18 @ 9:18 pm
Ah ok, if it's inbuilt only then try using the "ultraLatency" setting and see if it's any better.
Also make sure exclusiveAudioAccess is set to no
geposted Mon 19 Feb 18 @ 9:22 pm
What column headings are you using in the VDJ browser?
geposted Mon 19 Feb 18 @ 9:58 pm
