Topic: DDJ SZ 2 LAPTOPS
DDJ SZ Question: Who has a detailed explanation of how to run Virtual DJ and Serato at the same time on the SZ.
What are the limitations and what is the most one can expect? 2 Laptops, Windows 7, VDJ 8.2....No matter how I hook them up the other software says (in use) ...TY
geposted Thu 22 Mar 18 @ 2:21 am
938MyDJPRO InfinityMember since 2007
You have to press the USB selector A/B on top of the unit.
geposted Thu 22 Mar 18 @ 6:44 pm
they will never work at the same time that is not the intention of having dual USB ports.
the intention is quick laptop switches.
geposted Thu 22 Mar 18 @ 7:16 pm
beepbHome userMember since 2011
Actually, they can work. You just have to sacrifice whatever side the laptop that you want to use is plugged into. EG: Primary Laptop is Running VDJ And is USB A, Secondary is running Serato, and is USB B. Simply switch one of the sides to USB B, and Mix out.
geposted Tue 27 Mar 18 @ 6:51 pm
With a full Pro license. Just flick the switch over. Left A/B usb Right A/B usb USB A = one laptop USB B = Another laptop
geposted Tue 27 Mar 18 @ 10:39 pm
