Forum: Addons
Topic: Fix VirtualDJ Hosts Mac
geposted Thu 17 May 18 @ 8:05 pm
Ok , so i just used the Host Fix for my mac, and it say's that my system didn't required any fix, but i still can't login in the app .
Any help on my problem ?
geposted Sun 27 May 18 @ 12:37 pm
More details required - not just "can't login".
How are you logging in (what details are you using)? What happens when you try? Any message?
geposted Sun 27 May 18 @ 1:23 pm
"we cannot connect to virtual dj servers" . i'm just trying to log'in by my user and password. so i can use my console pioneer ddj-sb.
geposted Sun 27 May 18 @ 3:26 pm
I would suggest having a look yourself manually at the hosts file on your Mac to see if there's anything relating to virtualdj.com in it.
geposted Sun 27 May 18 @ 5:05 pm
Also check your firewall
geposted Sun 27 May 18 @ 5:09 pm
Firewall allows virtual to connect to the internet. In the hosts there is nothing related to virtualdj
geposted Mon 28 May 18 @ 9:49 am
