Forum: Addons
Topic: Equalizer 10
geposted Thu 17 May 18 @ 8:29 pm
Scott - I believe there used to be an eq addon for the ipad remote. Is there still a way to access the eq10 on the ipad?
I am new to the ipad remote so apologies if this is a stupid quiestion.
geposted Thu 14 Jun 18 @ 1:12 am
Bump
geposted Fri 15 Jun 18 @ 4:22 pm
Search the download/add-ons page. There's a graphic EQ there.
geposted Fri 15 Jun 18 @ 4:41 pm
I searched for that, it’s no longer there.
geposted Sun 17 Jun 18 @ 11:17 pm
There was never a sound effect for the remote, the remote doesn't deal with sound at all.
Honestly not sure if the remote displays effect_gui's, I presume so.
Download & install the mac or pc version of the eq xf and access them via the remote.
geposted Sun 17 Jun 18 @ 11:41 pm
Oh yes it is! I did check before I posted the previous message.
geposted Mon 18 Jun 18 @ 4:27 pm
Would you be kind enough to send the link? Please and thank you! :0)
geposted Mon 18 Jun 18 @ 8:57 pm
geposted Mon 18 Jun 18 @ 9:30 pm
kradcliffe wrote :
http://www.virtualdj.com/plugins/index.html?category=effects&search=equalizer
Yes, that's what this thread links to. My original question was that I thought there used to be an eq add on specific to the ipad. Maybe I am mistaken, but that was what my post was for.
Groovin mentioned there was a 'graphic eq' addon but when I search the ones you gave a link for were the only ones I found as well.
geposted Mon 18 Jun 18 @ 10:10 pm
It's a remote skin. Go to skin plugins and search for Kazoo.
geposted Mon 18 Jun 18 @ 10:37 pm
Thanks, but I'm looking for the 10 band eq plug in to appear on the ipad. This way you can go out in front of the setup to properly eq the master out.
geposted Tue 19 Jun 18 @ 2:48 am
dj fandosPRO InfinityModeratorMember since 2006
does not work on mac :(
geposted Thu 13 Dec 18 @ 3:19 am
Don't use the Web-installer (there may be a small bug - will be fixed). Try to install it from the "Extensions" tab of VirtualDJ
geposted Thu 13 Dec 18 @ 12:55 pm
