Forum: Addons
Topic: Sweep Auto
geposted Thu 17 May 18 @ 10:53 pm
fer14PRO InfinityMember since 2007
only windows ?
geposted Wed 17 Oct 18 @ 5:53 pm
lincol2PRO InfinityMember since 2011
unable to install on window 7
geposted Wed 17 Oct 18 @ 8:07 pm
Is this happening with just this Addon ? Have u tried to download/install a different one ?
If it happens with all, then something is preventing from installing at the "correct" path (such as write permissions to vdjfolder, some Antivirus blocking ... ) ?
geposted Wed 17 Oct 18 @ 8:46 pm
just try another which is fine
error is in sweep Auto
geposted Wed 17 Oct 18 @ 9:16 pm
cuando podran funcionar los mismos efectos sweep (ejemplo) para sistema osx ????
geposted Sun 22 Sep 19 @ 8:22 pm
Any hope for 64 bit version?
geposted Wed 20 Nov 19 @ 8:54 pm
This Auto Sweep Effect is not available to install from within Virtual DJ pro. Any update on availability ?
geposted Wed 26 Feb 20 @ 5:48 pm
andy-veoControlleristMember since 2016
Missing this effect in the 64-bit version of vdj. Hope there comes an update!
geposted Fri 19 Jun 20 @ 7:34 am
SveninoPRO InfinityMember since 2009
Yeah, this would be great to use in the 64bit version.
geposted Wed 10 Feb 21 @ 6:54 pm
Can it be said that this has become an essential function for mixing some types of music?
geposted Fri 12 Feb 21 @ 10:08 pm
No, not really.
Most DJ's will do it manually on club setups using the noise colorfx
geposted Sat 13 Feb 21 @ 6:30 am
Yes Klaus You are right. Of course.
In my case I´m adding to the mix my live-trumpet, accordion, ukulele...
So mostly both hands are busy.
Thats why an AUTO sweep would be very helpful.
But happiness comes to those who can wait ;-)
geposted Tue 13 Apr 21 @ 6:49 pm
geposted Tue 13 Apr 21 @ 8:23 pm
guys am looking for an update of 64 bits. any further idea how to install it?
geposted Thu 07 Dec 23 @ 11:45 pm
