Topic: Exclusive Audio Access causing Popping Noises
CueItUpPRO InfinityMember since 2014
I'm running v8.2 b4204 on Windows 10 with a DDJ-SB2. When I activated Exclusive Audio Access I get popping noises out my main output and my headphone jack. As soon as I turn it off it stops. From the forums this seems to be an ongoing issue that needs to be addressed. Glad I figured out what was causing it and even more glad it's not a bad USB port or controller. But it was a bit of a rougher night having to use my computer's sound card since I wasn't able to troubleshoot until I got home.
geposted Sun 20 May 18 @ 10:48 am
Usually that means you should increase the latency setting
geposted Sun 20 May 18 @ 11:02 am
