Forum: Addons
Topic: Cue Scratch
Discussion about Cue Scratch
This pads page offers the same Scratch patterns as the default Scratch page.
Additionally,
  • HotCue selection :
    - Hold SHIFT (or right-click) and Pad 1 to 8 and select Hotcue 1 to 8. Repeat to un-select. When a Hotcue is selected, the Scratch will start applying from the Hotcue position
    - If the selected Hotcue doesn't exist, the scratch will apply from the current position, but will also assign the selected HC number to the current position
    - If no Hotcue is selected, the Scratch will apply from the current position.
  • You can edit the Scratches (in DNA Editor) from the Pads page Menu
  • Parameter 1 selects the Hotcue (0 for none), same as if you use SHIFT+Pads
  • Page supports 16 Pads (with 16 scratch patterns in total and 16 Hotcues to select
Cue Scratch Pads page
Cue Scratch Pads page when SHIFT is pressed
Changelog:
ver.1.01
  • Fixed typo on Pad 4
geposted Sun 10 Jun 18 @ 3:19 am
How to get the scratch DNA on pads
geposted Mon 16 Jul 18 @ 4:40 am
It's a native pad in the any of the '18 builds.
geposted Mon 16 Jul 18 @ 4:45 am
Additionally,
Changelog:
ver.1.01
can not find in pads only in effects
geposted Mon 16 Jul 18 @ 6:37 am
What build of VDJ are you using? What skin are you using?
geposted Mon 16 Jul 18 @ 6:39 am
I am sorry i found it i was looking in the wrong place
geposted Mon 16 Jul 18 @ 7:00 am
Bump
I downloaded and installed but dont see a pads section nor is it in sampler am i using the wrong skin i tried the default VDJ 8 Skin
geposted Tue 19 Mar 19 @ 7:28 pm
Hulo i have a problem with cue scratch. I cant save scratch patterns. Pliz help me ma djz
geposted Sun 15 Dec 19 @ 10:01 am
Hi there, still cant save the scratch pads.
geposted Mon 05 Jun 23 @ 9:39 am
