About VirtualDJ and DJing in general
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
Topic: VIRTUAL DJ LOGO - Page: 1
HOW CAN I REMOVE THIS VIRTUAL DJ LOGO. FROM MINE HERE IT SAYS THAT THE VIRTUAL DJ AM USING IS NOT PRO, HOW CAN I PROCEED TO REMOVE THAT VIRTUAL LOGO PLEASE HELP ME. IF IT NEEDS FOR ME TO DOWNLOAD A PRO VIRTUAL DJ THEN HELP ME TO DIRECT WHERE TO BE DOWNLOADED THAT VIRTUAL DJ PRO AND IT'S LICENCE.
geposted Wed 13 Jun 18 @ 6:00 pm
STOP SHOUTING!
Please just type normally, using lower case and capitals where required.
Why do you need to remove the logo? Without a license you should only be using VDJ at home, so a logo should not be a problem.
Pro licenses can be purchased by clicking the 'buy' icon at the top of this web site.
geposted Wed 13 Jun 18 @ 6:23 pm
... and yes, Pro-license-user are able to remove the logo and replace it with their own one on video-screen.
But it's not possible to remove the logo on skins.
geposted Wed 13 Jun 18 @ 8:49 pm
freppaPRO InfinityMember since 2002
In the new Vdj 2018 we now have a new function with video skins.
It would be great if we (Pro members) could change the "video skin logo" for example to our own logo or names.
geposted Thu 14 Jun 18 @ 4:01 pm
What video skin logo? I haven't seen a logo in any video skins yet.
It's easy to add one, but does require you to edit the video skin PNG and XML.
geposted Thu 14 Jun 18 @ 4:49 pm
The small vdj domes on the videoskin counts as a logo, so if the domes are displayed vdj won't force a logo even for home users.
geposted Thu 14 Jun 18 @ 6:40 pm
This is what I am talking about groovin
And my question is, is it possible to change to your own logo or name ?
geposted Thu 14 Jun 18 @ 7:20 pm
No, because that isn't a bitmap image from the videoskin PNG file.
In the same way as the logo in a normal skin is displayed, it comes from the program file - specifically to stop people removing it.
geposted Thu 14 Jun 18 @ 7:35 pm
Of course it can be changed but....
You will need to add your own logo to the PNG then rework the XML to point at that image instead of the inbuilt logo.
geposted Thu 14 Jun 18 @ 7:57 pm
And why I can't remove the Logo from Skins?
It interferes with some many skins :-(
geposted Sun 17 Jun 18 @ 6:42 pm
You can remove the logo sinly by typing false instead of true at the line :
<logo circle="false" visibility="80%"> in group name , do this for the leftdeck and rightdeck
geposted Tue 19 Jun 18 @ 7:09 pm
bumpePRO InfinityMember since 2011
How can I get this done please, I would like to edit the PNG please give guidelines. Thanks
geposted Thu 21 Jun 18 @ 8:46 am
bumpe wrote :
... please give guidelines. Thanks
Open the skin-zipfile. Then you'll find xml-files and png-file.
Edit the png and save it with the same name.
zip xml+png.
Rename the zip-file and place it in the skin-directory of vdi.
;o)
geposted Thu 21 Jun 18 @ 3:10 pm
zip xml+png.
;o)
This is deprecated in VDJ 2018, you don't need to mess with zip files.
Just open settings, go to Interface page, click on the skin you want to edit, then click on "edit this skin..." on the top right corner.
geposted Thu 21 Jun 18 @ 3:38 pm
Damm ;o)
Another nice feature I forgot.
Sorry (I'm gettin' old...)
geposted Thu 21 Jun 18 @ 6:33 pm
I mean the Logo in Skins , not Video Skins...
Why can't remove this from a Skin?
I can change the Size from It , replace It , but when I need Place for other things I can't remove It :-(
Not Good to force users to use a Logo in a Skin .
geposted Fri 22 Jun 18 @ 3:29 pm
This was enforced after some serato users tried to use virtualdj in secret with a serato skin ))))
geposted Fri 22 Jun 18 @ 4:18 pm
The logo is Atomix branding. Just like the badge on a car, or the label on clothing, or on your TV (etc.).
Don't you think they're entitled to display the name of their product on the screen?
geposted Fri 22 Jun 18 @ 4:41 pm
The Logo is also in the Startscreen and can placed everywhere like settings ect. .
But it must no forced at a skin ! :-(
Example:
I have a skin where this logo hides a button, or down in the browser ertas obscured.
It bothers and it doesn't necessarily have to be in the skin where you work with.
If it is shown at startup, or in Settings, and info.
Where else is also not a logo in the working area of software!!!!!
Greatings
geposted Fri 22 Jun 18 @ 5:23 pm
Serato, Traktor, Rekordbox, PCDJ Dex - all branded with the name of the software and/or a logo. Plus with those, you can't change the skin.
geposted Fri 22 Jun 18 @ 6:03 pm
Seite : [>] [>>]
80%
