Forum: VirtualDJ Plugins
Topic: Half Speed Effect [Request]
bagpussPRO InfinityMember since 2003
I'm looking for a simple effect that when activated, will half the speed of the playing deck in its own slip mode. It would be suitable for the FX pads, as it would likely only be used for short duration.
Half speed is a common effect in audio production, usually for single or very few instruments such as a vocal shot with some layered FX. Being as it should be simple to implement, I'm surprised this effect hasn't found its way into DJ software.
Please note I'm looking for a plugin to do this, rather than a script.
geposted Tue 19 Jun 18 @ 10:52 am
Yeah i can make that.
Half speed but slip return obeys full speed?
geposted Tue 19 Jun 18 @ 11:42 am
Yes, it'd be great if you can :)
It could be made slightly more complex, with a choice of slip, no slip, master tempo on/off.
geposted Tue 19 Jun 18 @ 2:29 pm
Ok, what about a duration option?
Like pick between freehand on/off, or 1,2,4,8 beats auto off.
geposted Tue 19 Jun 18 @ 3:49 pm
Yes that makes complete sense.
geposted Tue 19 Jun 18 @ 6:27 pm
Are you sure you want mastertempo dropping by 50% is a whole octave as we know it gets a bit stretched at -12 semitones.
Actually i can see you'd want to turn MT off if it was on.
geposted Wed 27 Jun 18 @ 3:44 pm
Yes in this case, the artefacts would form part of the effect, whereas master tempo under normal conditions is something you want to be as transparent as possible.
geposted Wed 27 Jun 18 @ 4:45 pm
