Topic: V8.3 B4444 useVideoSkin and karaoke
If you are playing audio in Deck A and using the videoSkin (slider all the way to that deck) and load a karaoke on Deck B the videoSkin turns off. It appears to happen even if you have a karaoke loaded in a deck that is not even playing. Not sure if this is the expected or unexpected functionality with the useVideoSkin is set to auto or if the useVideoSkin should only applied to the active deck.
geposted Tue 19 Jun 18 @ 9:25 pm
This is the expected behavior. It's a security to make sure videoskin disappears if you're about to play a karaoke session.
If you don't need this security, you can just set the useVideoSkin setting to "yes", or you can right-click on the preview window to manually select to show the videoskin or not.
geposted Wed 20 Jun 18 @ 1:51 am
