I have the HP Envy x360 Convertible Series - i7 7500 - 2.70G 2.90G - 8Gigs Ram, 64 Bit..
The problem I'm having is I'll be playing tracks with no problem, and then I'll start a new track and it will skip along like a CD or Double up with an echo. I'm not using any controllers - just the software on the laptop. I've attached a video that you can see and hear for yourself. Also I open my performance panel during the video and you can see all is well with the computer. Also this computer is brand new. Thank you for any help.. I'm using version 8.2 b4291,,
https://youtu.be/-Ii6qZO3pFA
geposted Wed 20 Jun 18 @ 3:48 am
Check the audio set up.
Try disable your mic input ,
It happens on both decks?
geposted Wed 20 Jun 18 @ 4:36 am
Thanks I’ll try that. It only happens every once in a while. It can happen to any side of the deck.
geposted Wed 20 Jun 18 @ 4:43 am
Take a pic, and post your soundcard setup.
geposted Wed 20 Jun 18 @ 5:56 am
Okay trying to post a picture.
geposted Wed 20 Jun 18 @ 3:36 pm
Here's a link to my dropbox to see the picture.
https://www.dropbox.com/s/teuxie853stn87c/IMG_8661.jpg?dl=0
geposted Wed 20 Jun 18 @ 3:41 pm
No, I mean VDJ soundcard settings,
I may not be able to get back to you right away, because I just started spinning.
geposted Wed 20 Jun 18 @ 4:24 pm
Okay hold one sec..
geposted Wed 20 Jun 18 @ 4:25 pm
Here's the link, but how do i post the image directly ?
https://www.dropbox.com/s/ywvnpyaji2y7g3d/IMG_8663.jpg?dl=0
geposted Wed 20 Jun 18 @ 4:30 pm
Any idea with the last post I posted showing the graphics card ?
geposted Fri 22 Jun 18 @ 12:59 am
You do know you can take a picture of your computer screen without pointing your phone at it?
Use Google and search for the word screenshot...
geposted Fri 22 Jun 18 @ 5:07 pm
I didn't !
geposted Sat 23 Jun 18 @ 2:39 pm
Someone help please it keeps happening ..
geposted Sat 30 Jun 18 @ 5:22 pm
Now it just played throwing me multiple tempos and the next song was giving me double beats. Something isn't right please help...
geposted Sat 30 Jun 18 @ 5:29 pm
Does it also do it with different speakers/headphones?
Maybe it's because of the bluetooth?
geposted Sat 30 Jun 18 @ 5:32 pm
I'm running the same speaker setup with a line out from my headphone jack to a board. Should I turn bluetooth off ? I'm not using it though so I'm not sure if that would cause a problem.
geposted Sat 30 Jun 18 @ 5:33 pm
It's usually happens after a half hour of playing.
geposted Sat 30 Jun 18 @ 5:35 pm
yes turn the Bluetooth off and connect it via a cable and see what happens.
my Bluetooth headphones do all kind of weird stuff when the battery gets low or i have some interference.
geposted Sat 30 Jun 18 @ 5:41 pm
I turned bluetooth off.
For the record I've never used it.
Always with a line out to the board.
geposted Sat 30 Jun 18 @ 5:42 pm
are you running the speaker on battery power maybe the battery gets low and it acts weird?
just a guess here
just a guess here
geposted Sat 30 Jun 18 @ 5:44 pm
