Topic: Latency between headphones and speakers
FragsPRO SubscriberMember since 2018
Hi hoping someone can help. I purchased the HOME PLUS ANOLOGUE MIXER for VJ8. The issue Im having is latency between headphones and speakers. I have downloaded and running ASIO4ALL V2, and still no solution. Im also using a Sound Blaster 5.1 soundcard. Cheers Gary
geposted Mon 16 Jul 18 @ 6:24 am
https://www.virtualdj.com/wiki/ASIO4ALL.html
If your audio interface suffers from latency (consumer ones typically do) then you will need to buy something designed for the job, with a real low latency ASIO driver - not ASIO4ALL (see above link).
geposted Mon 16 Jul 18 @ 6:37 am
