Hi, I am hearing a persistent clicking noise both in the headphones and through the speakers when using my MixTrack Pro 3. I have VDJ 8 Infinity and running it on windows 10. Can anyone help please.
geposted Sat 28 Jul 18 @ 8:01 pm
wasapi or asio?
latency settings.
do you get acceptable results with http://www.resplendence.com/latencymon
latency settings.
geposted Sat 28 Jul 18 @ 8:25 pm
locodog wrote :
wasapi or asio?
latency settings.
latency settings.
....wasapi. Thanks
geposted Sun 29 Jul 18 @ 12:49 am
have you checked the windows isn't using your sound card for system sounds?
windows volume mixer.
geposted Sun 29 Jul 18 @ 12:51 am
For wasapi, you can also try to turn on exclusiveAudioAccess in options (or turn it off if it was on)
geposted Sun 29 Jul 18 @ 7:15 am
Hi, thanks for the tip. Turning OFF the exclusiveAudioAccess does get rid of the clicking but it reduces the volume (and overall sound quality) and puts me at the mercy of the computer's own volume control - is there perhaps some kind of compromise?
geposted Mon 30 Jul 18 @ 6:18 am
If you put the computer volume max it should be similar. Also make sure no sound effects are enabled in the windows settings
geposted Mon 30 Jul 18 @ 10:07 am
Seems odd that turning exclusive audio off would be an answer, could you give a quick reasoning please? I could just accept it without understanding, but better to know.
geposted Mon 30 Jul 18 @ 10:14 am
I'm just happy that it's worked but, yes, some understanding might be helpful.
geposted Wed 01 Aug 18 @ 6:09 am
buddy, increase your buffersize a little. it might add a few milliseconds but will take away the clicking sound. have you tried it on another computer with the same result?
geposted Mon 13 Aug 18 @ 10:51 am
