(NOTE: VirtualDJ continuously updated, so many older topic on this forum are most probably already fixed in the current build)
If you need extended support, contact our Support Team.
Forum Guidelines (*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
My files are on an external drive, so i can use it also on a second notebook in case of emergency.
I have a copy of these files on the c-drive, and also there the videotags are gone
If i'm correct, you cannot tag videofiles on their own, but the tags are saved within VDJ.
The problem has occured more in the older videocodecs (mpg, wmv,...)
What can be the cause of this happening?
How can i prevent this from happening again?
Is this caused by a update of VDJ, or an update in Windows?
Which possibiliteis are there that i something to cause this?
thnx, grtz
geposted Mon 13 Aug 18 @ 10:12 am
You can check both files modified date, perhaps there's a permission issue preventing vdj from reading this file
geposted Mon 13 Aug 18 @ 10:23 am
The tags are gene in the xml file
The question... How come?
geposted Mon 13 Aug 18 @ 11:22 pm
geposted Sat 18 Aug 18 @ 4:53 am
