Topic: Random Autoplay
Is it possible to create some random autoplay button on vdj8 ? So when you have a usb-stick plugged in , it automatically plays songs in random order ? I would be very happy with an option like that . It would be ideal to discover all the music I downloaded .
geposted Mon 13 Aug 18 @ 10:28 am
Just locate the pen drive in browser, drag the files to the automix window, hit the cog and select shuffle.
geposted Mon 13 Aug 18 @ 10:56 am
Just put them into automix and hit shuffle.
geposted Mon 13 Aug 18 @ 10:57 am
How am I supposed to drag 3000 songs to the automix-window ? Is it possible to do it all in one step ?
edit : I allready found out how to drag the USB-station to automix , but now I cant find the shuffle-button .
geposted Mon 13 Aug 18 @ 11:11 am
Ctrl+a to select all. Basic PC stuff.
Press the cog at the right hand side of the automix window. All this is covered in the user manual.
geposted Mon 13 Aug 18 @ 11:38 am
Thanks !!! It works for me now , sometimes a simple hint is better than finding out yourself .
geposted Mon 13 Aug 18 @ 11:43 am
