I am especially interest in...
-Transparency option for shaders
-Video skins for karaoke mode
. Delay effect is pretty cool, when used only as needed (:>)
geposted Mon 13 Aug 18 @ 10:25 pm
what specifically are you looking for that isn't mentioned in the Change Log?
http://www.virtualdj.com/products/virtualdj/changelog.html
geposted Tue 14 Aug 18 @ 12:59 am
I want to know how the features work... I need to read some words or see some examples.
geposted Tue 14 Aug 18 @ 1:53 am
If you look under karaoke in the settings/options you can now enable/disable a video skin that overlays when in karaoke mode. My guess is that there will be more skins to come
Regarding shader transparency I made a quick example:
geposted Tue 14 Aug 18 @ 2:38 am
