Topic: How to remove songs from Favorite Folder
Couldn't find info in the manual. How do I remove songs from Favorite Folder?
Thanks!
geposted Fri 07 Sep 18 @ 4:46 pm
A favorite folder shows all files located inside the physical folder it points to.
The only way to remove a file from a favorite folder is to delete the file itself (either from inside VirtualDJ browser, or either from Explorer/Finder)
geposted Fri 07 Sep 18 @ 6:09 pm
But I have created a Favorite Folder from a playlist, and I added new songs by dragging them into it. Now I need to remove some.
No option like that.
The only option I see right now, is moving all songs to Side List, removing unwanted ones, saving a new playlist, and making it a Favorite Folder. Hmmmm.
Am I doing smth incorrectly?
geposted Fri 07 Sep 18 @ 9:55 pm
Use a virtual folder instead. You can add and remove to them freely.
geposted Fri 07 Sep 18 @ 11:14 pm
Delayed answer but that worked. That is the solution. Thanks!
geposted Sun 18 Nov 18 @ 5:31 pm
