Hi
mac os 11
vdj 8.3 ( 2018 ? ) build 4592
controller denon mc6000 mk2
skin swap 2.2 by djdad
question :
on the skin there is this "browser zoom" button which toggles "almost fullscreen" browsing on/off.
How do I change the mapping on mc6000mk2 button "panel"/"view" to use that functionality ?
Properbly a rtfm question, sorry, but please point me in the right direction.
Kind regards
Steen
BTW : sync to SUNLITE : thanks a lot :-)
about the guide : you could point out that sync follows the masterdesck and how to choose masterdeck on the swap skin or something else, It could have saved me some time, default skins doesnt (?) have the "choose masterdeck" functionality , which I was using ...
mac os 11
question :
Kind regards
Steen
geposted Wed 10 Oct 18 @ 8:24 pm
Go in to the mapping section, click the eye dropper icon (aka erm.. script learn) then click the zoom button on the skin, this will give you the script attached to the skin element.
And yeah with vdj it's well worth reading the manual, you'll probably end up with more questions than before reading but they'll be better questions.
geposted Thu 11 Oct 18 @ 5:42 am
Use this action..
http://www.virtualdj.com/manuals/virtualdj/settings/controllers/index.html
By Default Masterdeck is deck that plays out live, regardless the number of decks. Usually you would want to change that (and manually select different deck) if you want the SYNC button to synchronize the deck not to the Masterdeck (as in most cases you would want) but to some other. For 2 decks, this case doesnt make sense, as all you have is 2 decks, thats why the MasterDeck buttons exist only in 4-decks skins.
toggle '@$browser'
geposted Thu 11 Oct 18 @ 6:05 am
Hi
thanks and it worked :-)
kind regards
Steen
kind regards
Steen
geposted Sun 14 Oct 18 @ 8:52 am
