my vd suddenly can not read tracks that it did read before. i get the message "unknown file type" on deck
geposted Thu 11 Oct 18 @ 9:14 am
What is the file extension type?
geposted Thu 11 Oct 18 @ 9:22 am
It might also mean that the file is not found anymore.
Check the file path in tag editor and see if it was moved perhaps.
geposted Thu 11 Oct 18 @ 9:25 am
Does anyone resolve this issue and how. im having it right now, check the file path and its correct the file its playable in other media players. any ideas
geposted Fri 12 Apr 19 @ 6:04 pm
What type of file is it? Are you sure it's a type supported by VDJ (has it played OK before)?
geposted Fri 12 Apr 19 @ 6:34 pm
Augh! I was wrong! But I did fix it. One way is to import every single track into it through the Finder. AUGH! There has to be a better way!
geposted Fri 18 Dec 20 @ 8:33 pm
Ok! This time I really did fix it! It's easier than you think.
Right click on "iTunes" in the Browser and click "Reload." That's it.
Happy Setting,
Much Love Always,
MSAS
Happy Setting,
Much Love Always,
MSAS
geposted Fri 18 Dec 20 @ 8:46 pm
I am having the same issue. The file plays when I initially put it in. When I close VdJ and open it back up it says unknown file type
geposted Sun 10 Jan 21 @ 2:38 pm
I was going to upgrade to pro but this issue is really problamatic
geposted Sun 10 Jan 21 @ 2:39 pm
Sounds like a very old bug fixed a long time ago:
There was issue in some tag writing making the file readable at first but not readable anymore once the tag was written
(ENDIANNESS error in some numeric field)
If the file reads OK in some other software try to remove tags and reloading it in VDJ
if it reloads chance the bug came back :/
geposted Sun 10 Jan 21 @ 5:21 pm
geposted Thu 06 Oct 22 @ 8:30 pm
