Anybody who's good with filter folders, can you tell me the Syntax filter. to make a folder that will populate with all songs 128kbs and below ? thanks somebody suggest i use "Group by Bitrate" but that comes up like this. which i dont want to click through all the folders to delete everything below 128kbps i'm wanting one folder that i can choose all the songs at once & delete thanks
geposted Sun 14 Oct 18 @ 5:15 pm
Done by Filterfolder ;o)
BTW:
You can't convert (scale up) files up from a lower bitrate.
geposted Sun 14 Oct 18 @ 5:40 pm
a better one:
geposted Sun 14 Oct 18 @ 6:25 pm
Sorry. I didn't read that you have already done this with a grouped filter. My mistake.
PS:
If you want files below 128 you got to filter
Bitrate < 128
geposted Sun 14 Oct 18 @ 6:28 pm
PS:
Bitrate < 128
PS:
Bitrate < 128
Thank u sir worker perfectly :-)
geposted Sun 14 Oct 18 @ 6:55 pm
np ;o)
geposted Sun 14 Oct 18 @ 7:54 pm
